Need help with a sequencer.
Hi, I wasn't sure where to post this. I play a Yamaha TX81Z synthesizer and I need a sequencer. I was thinking of getting a Yamaha RS7000, but I need to know something first. I'm kind of new to the digital music world, and it seems that the RS7000 doesn't record any sounds, rather it stores the notes you play, then plays them itself. Okay, now for the problem. My TX81Z has a lot of instruments, it seems if I changed the instrument to play something over a loop I record, it would ether A, record the time it took me to change the instrument, or B, not register the change at all, and play the same notes with the new instrument I select. Does it work like that? Can anyone help with this? Thanks.
josetabito
