PSR 620
Lakewood, Ohio
This keyboard that I formerly used let me creat my best discs that I used in it but then it quit working. How can I get those SGD files converted into another format like midi or wave?
Thanks
If I understand correctly your floppydrive is not working anymore? If you have songs on floppies and they are recorded on your keyboard they are in midi already. You can get a floppydrive with a USB connector for a little money and transfer your recordings to a PC. You might have to change the name xxx.sgd to xxx.mid. Also midi's don't sound very good on a PC as most soundcards are limited to 'only' 127 voices. If you have done this, you can record the midi's as wav or mp3 in ie Audacity, a free and good recording program.
