RD300SX Soft Case?
NJ
Does anybody know a soft case with wheels that will work for the RD00SX?
Thanks-
I've had a RoadRunner wheeled soft case for almost 2 years now for my RD700SX with no REAL complaints. Yes, in a perfect world I'd much rather have a hard case or something with real heavy internal padding, but I guess 2 years is pretty good. I see there's a "slim" version of this case (At half the price my full sized one was!:mad:) that I bet would work for you but check and double check your measurements.
Road Runner RR Xpress Keyboard Porter Sm88 and more Keyboard Instruments at GuitarCenter.com.
My only quibbles with my case have been:
-although the length is perfect it's a little too wide. I bet the slim version would be good for me, too.
-The mesh pocket on the outside of the "pedal pocket" tears easily as I found out.
Hope you find this helpful.
