Viscount Legend Editor (exp) question
United States
Dear all,
I tried posting this at the Viscount support page but it said i didn't do "captcha" correctly (but there was no captcha available). Sigh.
I want to use the Editor software to change the Overdrive model to something that is raunchier than the default. Anyone know which one i should try?
Also, i've not connected it yet to the unit (which is not connected to a keyboard at the moment so i can't easily trial-and-error), I noticed that some of the defaults in the pull-down menu are different from what is set on the unit. When i connect the editor to the unit, will these defaults repopulate to what the instrument is set with, or do they stay the same in the Editor and I have to manually make sure they match what is in the instrument before i write the desired changes.
Thx for your help, as always.
Keymans
