Which Keyboard
Hi, can anyone recommend a keyboard with drum beats etc for a 2-piece country and western, Irish country,rock n roll band? cheers
USA
This forum is to introduce yourself to the members of this forum. If you wish to ask a question like this, please use the other forums.
I would use a Yamaha PSR-E213, might need an amp...
Welcome to the forum.
Welcome to the forums!
Take a look at the keyboards in the arranger category. Like Riotblade suggested, start with Yamaha and broaden your search as necessary from there.
At some point you will have to do some in-store test driving to see what you like. Don't worry about not knowing anything. Just wander in, and the staff should have no problem with spending as long as you like trying out the goods.
josetabito
