Yamaha s90xs question (transposing)
Is it possible to save transposed voices?
For example, could I have one a voice saved in preset 1 transposed up 3 notes, and then preset 2 transposed down 4 notes, etc?
I read through the user manual and didn't see anything regarding that. I have experience using Clavinova keyboards but not with a synth like this one. Any help would be greatly appreciated!!
Thank you!
If it's anything like the motif (and it should be) It can be done in the performance mode.
List through the part options in performance mode, and you should find the transpose setting for each part of the performance. Edit the sounds in a way you like and save them. It should work then
