Buying Motif XF. Is 61 key enough?
Hi guys,
I've decided to buy the Motif XF. I really wanted the 73 key but all I can afford is the 61.
I survived for 7 years with just a 61 key board, so I assume it will still work for me.
Im not a serious pianist, I just play in a cover band.
Anyway, I just wanted some reassurance that the XF6 would be fine...
XF6 would be fine?!... it would be GREAT man! you won't have to regret on buying a 61 key keyboard as you told that you are not a serious pianist.... above that motif XF6 has FSX KEYBOARD!!!!!!!!!!!!!!!!!!.....GREAT!....go for it! 61 key and 73 key, both are almost the same things..... they both have FSX keyboard so it's alright buying XF6
