Casio MZX
Hi
Just wondering if the Casio MZX range are a quality instrument as I've never seen one used professionally
Many Thanks
It's definitely priced like a pro instrument and Casio Privia Pianos are widely used on stage.
Probably the reason you haven't seen one used on stage is that it's an arranger keyboard and arrangers are not usually the first choice for live performances.
You might want to ask over on http://casiomusicforums.com if you need more info on that model.
John C.
