e433 won't save settings
(almost) Every time I turn off the machine my settings changed in the functions menu reset to previous...i want the master volume to be lower, I succeeded in setting it at 122 once but now I can't seem to get any changes to take hold, is there a way to finalize my choices before turning off the machine?
How old is the keyboard? Yamaha states on the first page of the manual that it MAY contain a Lithium button battery that's soldered into place.
If the battery needs replacing it's not really a DIY job on a Yamaha unless you are comfortable working with electronics and the unit is out of warranty.
The main volume isn't one of the function settings that get preserved when the keyboard is turned off. Only 16 function settings are preserved; they're listed on page 32 of the PSR-E433's owner's manual. The other 47 function settings, plus all the panel settings that aren't listed in the function menu, are set to their default values when the keyboard is powered up.
The main volume and other voice-related functions-- including the functions related to the reverb, chorus, harmony, and arpeggio-- are set to specific defaults according to the main voice that's been selected. The exceptions are the voice number and function settings related to the split voice-- they're changed if you select one of the "Left" arpeggio voices (i.e., voices 260 through 269), but otherwise are left unchanged when you change the main voice.
As it happens, the main volume-- the volume for the main voice-- has a default setting of 122 for voice 001, which is the voice number that the keyboard defaults to when you power it up.
Fortunately, there is a way to set the main volume and save it-- by saving the panel settings to one of the 32 registrations (i.e., 8 banks of 4 registrations). Unfortunately, when you select a different voice number for the main voice, the main volume will get changed to the default for that particular voice-- so if you don't like the default main volume for that voice, you'll need to change it and then save it as another registration.
Bradders
