Help me fix my keyboard plsss
Hey so, my keyboard has a problem that when i press the spacebar for long it works then it lags (it does the long space line and then it freezes) and after 1mn it stops and it doesnt respond... one more thing is that when the spacebar is locked, the windows key is blocked too.
Middle C could be causing the problem. It is located just above the space bar but slightly offset to the left. Try moving your device a little to the right. Hold the space bar down for a full four beats of every bar.
Good luck :)
DOES YOUR KEYBOARD LOOK LIKE THIS???????
Africa-Ghana
Hello.. I’m new here and I really need help.. I stopped using my Casiotone 202 for sometime and today I wanted to try something with it.. And none of the keys are working.. There’s no sound.. What could be the problem here please.. Anyone help
Casios are famous for sudden death.
They cost more to fix than they are worth.
Try batteries to see if it's the power supply.
If it still doesn't work then scrap it.
Bradders
