Depends on how you plan on using it. Do you plan on attaching it after the out on your keyboard or do you plan on using it as an effect in your sequencer and sampling it?
Many keyboard players use outside gear (including guitar pedals) all the time.
You would want to record without the effects and then re record the already recorded keyboard sound with the effects.
Since keyboards are designed to be in stereo... and guitars are in mono... wouldn't guitar pedals not be a good idea? Or do some guitar pedals have stereo input/output?
Well that's good to know! So if I bought a Loop pedal, I could loop my stuff in realtime on the keys?? awesome!!
How would you do that? You mean apply the effects on the computer? (I have Cubase LE).
When using the guitar pedals, from what I've seen, they were used in such a way as to help replicate the sound of the instrument better.
I have a Yamaha MM6, which is just a basic keyboard without a million effects, and I have an Alesis Micron, which is a nice little synth but only has 37 keys so I wouldn't use it as a primary.I have to wonder what kind of keyboard you have as most keyboards will loop in realtime anyway.
I knew someone was going to mention MIDI to me!You could check on different MIDI capable devices to do this for your - not sure a loop pedal is the best way to accomplish looping on a keyboard. That's just my opinion, of course, and if you have an idea and can make it work - cool!!
I have a Lexicon Lambda recording interface that has a few audio inputs, a mic input and a MIDI in & out input. My Yamaha also uses a USB for MIDI. I only have 512 MB RAM on my computer, so it doesn't handle VST too well. In general, the computer & MIDI may be great someday when I want to create an album, but for jamming right now, it's a buzz-kill.how do you get your keyboard sounds into the computer in the first place? If you could explain your setup and how you get your music into Cubase LE, I could answer this a bit better.
Hahah...I already spent my allowance.I would just hate to see you spend money on something that might be sort of useful when you can spend your money on upgrading equipment (and aren't we always dreaming about that new keyboard or rackmount item??).
