What keyboard to buy ?
Hii. I'm urgently need to purchase a keyboard (Yamaha). The problem is that the only available models here are E343 & the other lower models which I'm not preferring AT ALL. E433 is a discontinued model and there's no sign of E443, ANYWHERE. Moreover I425 & I455 are to be found all over. Then I don't want either of these I series cz they're Indian versions. Plus, the S series are way too out of budget. Though I may consider S550 B.
Plz help. It's really urgent.
Although the PSR-E433 is discontinued as of last year, it should still be available from online sellers-- although the PSR-E443 is a better buy.
If you say the PSR-I425 and PSR-I455 are "all over," I'm guessing you're in India or somewhere thereabouts-- is that right? If none of the local dealers have the PSR-E443 in stock, have you tried purchasing online?
http://www.amazon.in/Yamaha-PSR-E44...=UTF8&qid=1422101042&sr=8-1&keywords=psr-e443
Yeah, you got that correct. I'm in india that's the reason I'm surrounded with i425s & i455s. I have been hunting for e443 and e433 (e443 being my preference) but none of them are available, not even online sellers. Being a student makes it even harder because of the limited budget.
PS. In no condition I'm going for those Indian ones. CERTAINLY NOT MY TYPE...
Also wanting to know what would be better e443 or s550B ... ignoring the fact that e series is for beginners and S series is kinda professional.
Still urgent. ..
The PSR-S550B is fully XG-compatible, whereas the PSR-E443 is only XGlite-compatible. The PSR-S550B can do more than the PSR-E443 and would be a better buy.
