I don't really see how you can use a condenser mic with a Casio since there's no way it can supply phantom power to the mic.
One possible solution is to devote a cheap; $45 Behringer 502 5 channel Mixer with an XLR input and phantom power and route the output to the Casio's line level input if it has one.
http://www.amazon.com/Behringer-502-XENYX502-5-Channel-Mixer/dp/B000J5UEGQ
So do you think I'd be better off keeping my Sure SM57 for recording acoustic instruments from several feet away or do I need to live with close miking with it to get the most out of it compared to trying to rig a condenser mike?Either one would probably work just as well. Read Page E12 of the manual on how to hook it up to the RECORD/Inst IN Jack.
Only problem I have with the preamp you listed is that it's a tube amp. Personally I hate tubes. They're a pain in the ass and they are constantly burning out. Why on earth would anyone want to hook up 1950's technology to a modern instrument is beyond me.
All that a tube adds to an audio circuit is about 2% THD.
As I understand the diagram above, the mike is vertical facing south. I was picturing the mike on the boom in the middle of the group pointing straight DOWN. If it is pointed straight down, the horns would be picked up uniformly plus get the reflection (reinforcement) off the concrete floor.You're welcome.
However, I will mention one small detail.
A circular arrangement won't work that well with a cardioid pattern mic. It's a directional heart shaped pattern of sensitivity that won't pick up properly in a 360 degree pattern. You'll have to arrange your players in more of a semi circle about 170 degrees apart from end to end. Even then that may not be optimal. Here's a diagram of the SM57's cardioid pattern. It seems to be pretty even coverage from end to end about 180 degrees.
What I was going to suggest, until you mentioned that money was tight, was that you invest in an electric pickup for each clarinet.
http://www.pasoana.com/
Otherwise I'd suggest getting a second SM57 and feeding both mics thru a mixer and then doing your final recording and effects on the computer instead of thru the keyboard.
I might have randomly picked a pricey one. They all can't be that much.I.
Anyway, I had no idea that clarinet pickups were so god awful expensive. Flute pickups can be had for well under $200.
