Keyboard stand
Col
Hi guys.
I need a decent stand for my yamaha PSR Ew310 keyboard, but would need it to be easily folded and put away, if you can recommend any as there were a few to choose from on amazon and I wasnt sure.
Thanks All
Normally advice tends to lead away from X stands but for speed of set up/take down they are hard to beat.
You will find X stands from £15 upwards but on brand name alone K&M make some of the best stands out there, and theirs will last a lifetime
Not cheap at £57 but it will be top quality.
A downside of X stands is some can be flimsy and double X is a safer long term buy and the X construction can get in the way when seated.
An alternative is a table stand as per.
Michigan, US
I just use a simple X stand for my lightweight PSR but if I had a heavier one I would consider this K&R:
Col
Thanks again Biggles that's great.
Michigan, US
Correct me if I'm wrong but the EW models are 76 keys, right?
For a longer keyboard, an X stand is a poor choice. It will have a tendency to tip off the stand when you play the lowest and highest notes with any sort of vigour.
Depends if he's sitting or standing though since X stands are wider at lower settings.
