Help Required with SD Card-Casio CTK-810IN
Hi,
I am new to this site and this is my first post.
I am trying to use SD card with my Casio CTK 810 IN.
I tried both SDHC card and Micro SD card.
When I insert card and press the Card button, the screen says "Err Format'.
Please help me regarding this
I want to record my performance and use it later for practice and transfer it to computer.
Thanks & Regards,
Shridhar
Chester-le-street. County Durham . U.K.
Hi Shridhar,
I do not own a CTK 810 IN but a CTK-7200 and in the manual for my keyboard
the SDHC card MUST be formatted by the keyboard for it to read it correctly
So have a look at the manual with regards to formatting the SDHC card.
Hope this helps a little George
Hi Fellwalker,
Thank you very much for your response.
But the problem is the maual which I have does not say anything about SD card.
I do not know how to format the card through keyboard.
Will it be possible for you to paste that info here if your manual has the same.
It would be a great help.
Thanks in advance.
Shridhar
Is it possible to record my performance and move it to my computer through USB cable.
If yes then can you provide me the steps.
Hej Shridar,
download the manual for CTK-850IN and read page E-60. Their they describe how to format a SD-card.
Torbjörn
Thanks a lot for your reply Goldi :)
This forum is excellent.
I get very quick replies.
The problem is I cannot find manual for CTK-810 IN. The site provides manual for CTK-810 not for IN.
And in that the pages are only till E-57.
Can you please provide me a link to download manual for CTK-810IN.
I wil lbe very grateful.
Tanks in advance
Hi George,
I have the same manual :)
There is nothing mentioned for SD card in this manual.
Anyways, I will try to download manuals of some other instruments.
Thanks for your help..
Sweden
Tanks in advance
Hej Shridhar,
you should download CTK-850IN (not CTK-810IN this I didn't find). And in 850IN see page E-60.
Hej Shridhar,
Hi Goldi,
Thank you very much.
This pdf contains all the information related to SD card.
But while following the steps I am stuck again at one place.
When I pressed on Yes to start formatting the screen first says 'please wait'
and moments later it says "Err Format"
I have already formatted the card and removed its write protection.
Do you have any idea on how to resolve it?
Thanks & Regards,
Shridhar
Hi,
Thanks & Regards,
Shridhar
I have also the same problem....
Hi,
Thanks & Regards,
Shridhar
Now I can play files from my SD Card, These are the steps I have done,
1 Changed my SD card,
2 Formatted card from laptop
3 Created a folder named "MUSICDAT"
4 converted MIDI files to .CM2 file using casio SMF converter in Windows XP
5 copy these files to the folder MUSICDAT
6 Inserted card in the keyboard
7 Selected the key CARD
8 Press button play.
Once More Thanks everyone for the support..
hi
Thanks for the the above info. I was infact trying different ways..
I used my existing SD card (that i had for my camera) for my 860in, and i too was getting the same error as Sridhar..
When i read that i need to buy a new SD Card, i thought "another bit of purchase again'
But thanks to Nidhin comments
Steps that i followed
a. created a Folder named "MUSICDAT"
b. copied the converted MIDI files into the folder
c. inserted card in the keyboard
d. Load the card
and Lo it worked...
