SK 560 No power
Hi folks....my kids keyboard has just quit! Tried a different powers supply lead and still doesent work. Tried batteries too and still no power. Would be greatly appreciated if someone could shed some light and I could get it going again for her?
You have checked all the likely at fault items.
If you are handy with a screwdriver you could also check for loose connections internally or a breakage on the power board.
It is a £56 keyboard and not worth seeking to have it repaired by a Tech.
Ok...thankyou. I might just pull it apart then to see for any loose wires etc.
Got it going! Pulled the back off it and noticed a wire off the on off switch!
John C.
