which keyboard should I get?
I have the Yamaha MO8 workstation and I need a smaller more portable keyboard. something cheap with only 61 keys. any suggestions?
thanks, King Ben
New or used, doesn't matter as long as it's in pretty good condition. Probably under $1,200. Arranger, color screen if possible.
the Yamaha psr-s910 seems to be what Im looking for, but it is a bit outside of my budget, if you know of a used one for sale that would be great.
I just like color screens lol
thanks for the recommendation the psr3000 seems perfect. can you load more styles on to it?
Yea you can. it's a high-end PSR keyboard that was basically a baby Tyros2, just like the s910 is a baby tyros 3... And Just like the PSR2x00 was a baby Tyros 1 :D
Hull, East Yorkshire, U.K
More keyboards to check out.
Roland G70
Korg PA500
Yamaha Tyros 2
Korg PA1x
All these models have been on the market for a few years and are now reduced or availible second hand. Most would have been top of the range and just replaced by new models.
John C.
